Whats needed for header install? List
Old Mar 1, 2009 | 10:32 AM
1gt2nv's Avatar
Default Whats needed for header install? List
I bought coated pacesetter headers, 2 o2 sims and a y pipe for my car. I already have a slp cat back. What else should I get before I do the install and where is a good place to buy from? I think I'll need new gaskets?
Old Mar 1, 2009 | 11:46 AM
84ta406's Avatar
New header gaskets. I was told to always use the metal ones from GM.
Old Mar 1, 2009 | 12:15 PM
1gt2nv's Avatar
Should I replace the motor mounts while I'm at it?
Old Mar 1, 2009 | 01:55 PM
98TAjwh's Avatar
+1 for the gaskets, and it is highly recommended to replace the motor mounts with poly mounts while your at it to prevent header knocking
Old Mar 1, 2009 | 02:31 PM
TORCHD 02 TA's Avatar
New GM Header Gaskets
Poly Motor Mounts
New NGK Plugs
New MSD Wires
Stage 8 Locking Header Bolts
02 Extensions
Old Mar 1, 2009 | 03:01 PM
1gt2nv's Avatar
Where do you get the poly mounts from?
Old Mar 1, 2009 | 03:10 PM
1998Z28LOADED's Avatar
15mm racheting wrench will make the motor mounts a lot easier, along with a 10 for the header bolts.
Old Mar 1, 2009 | 03:26 PM
Dskeet6's Avatar
10mm ratcheting wrench.... saves ALOT OF TIME!!!
headers and y-pipe
New gaskets
re-use stock bolts if they are untouched already
if car is lower mileage and coil wires are in good shape - reuse
3'' stainless band clamps
02 extensions instead of Sims
get a $40 tune to get rid of emission codes.... check engine light will never come on.
Old Mar 1, 2009 | 03:37 PM
http://www.ws6project.com/user_stor/...oducts_id=1490
Old Mar 1, 2009 | 05:07 PM
mrnorm_hemicide's Avatar
For the record, I just did poly mounts and I don't think I used the 13mm racheting that everyone says is mandatory ONCE lol. When the headers are out its possible to get a 3/8 rachet in there are virtually any of the 8 bolts. Poly mounts should be included with any headers you buy for f-bodies. I learned the hard way when I did the headers the first time and the y-pipe banged like a south side hooker. Had to basically do the job again to replace the mounts
Old Mar 1, 2009 | 08:47 PM
98TAjwh's Avatar
spohn has them for a decent price
