Z06 MAF on a LS1
Old Mar 2, 2009 | 10:23 AM
The Postman's Avatar
Default Z06 MAF on a LS1
On Judson's 99 Camaro they took a Z06 85mm MAF and used it in place of the stock 78mm....are the weather pack connectors on the stock LS1 MAF the same as the Z06 MAF?..I believe that its a certain year model of MAF off the Z06..does anyone know anything about the compatibility of the connectors?
and don't tell me it won't work, its already been done im just trying to duplicate it.
Old Mar 2, 2009 | 11:54 AM
Dskeet6's Avatar
i think you need a 5-wire harness with the 85mm MAF..... because the IAT sensor is on the MAF itself...... you will also need to tune your MAF table.... meaning take it to a tuner
Old Mar 2, 2009 | 12:28 PM
Medic/Z28's Avatar
Dskeet6 is right. It is a 5 wire harness plug. I picked up a truck MAF ,which is the same as a z06, had a pigtail done for it so it looks OG/OEM along with a coupler to mate it and the lid. Took it to my tuner. He did not have a stock Z06 table on his laptop so he found the closest set up to it.
Old Mar 2, 2009 | 12:38 PM
sroach20's Avatar
i just used this:
http://www.byunspeed.com/product_inf...oducts_id=9211
it says lt1 into ls1 but it does the ls1 to the 5 wire maf.
Old Mar 2, 2009 | 01:04 PM
thanks guys!..exactly what i needed
Old Mar 2, 2009 | 03:02 PM
Medic/Z28's Avatar
Yep. That's what I had made. Guy said he'd do work for GM, Ford and Mopar.
