Mezeire water pump?
Old Mar 2, 2009 | 07:21 PM
MeanGreen's Avatar
Default Mezeire water pump?
What size belt is needed with this water pump and what other modifications are need to put in the water pump? Help is appreciated.
Old Mar 2, 2009 | 07:24 PM
MeentSS02's Avatar
Kleeborp the Moderator™
The Meziere uses the same belt that your stock pump does - the idler pulley on it is the same size as stock to retain the stock routing and belt size.
If it doesn't come with a thermostat already installed, you'll need one for a small block chevy (old school), and it goes in the upper neck, not the lower one like the stock thermostat. You must also remove the stock thermostat from its housing - you can use the stock housing, but not with the thermostat installed.
I had to clearance the bottom of the cam on the throttle body (what the cable connects to) to get it to clear, but other than that, that's it.
www.ls1howto.com has more info.
