Need a Pic! And info on a fitting...
I need a pic of the power steering return hose routing on a stock Corvette ('03) front drive. That would be the small (3/8"?) hose on the bottom front of the reservoir. From the looks of it, the hose will really be in the way (hard to hide).
Also, is there an adapter fitting for the high-pressure outlet from the pump to a -6AN hose?
Thanks!
Russ
http://www.speedwaymotors.com/Power-...tings,965.html
Russ
