injectors question
Old Mar 6, 2009 | 09:25 AM
mandreake's Avatar
Default injectors question
guys pls answer .....i have a camaro 99 h/c lloyd elliot...hoockers lt, 373 gears, 3600 yank, ....and Im porting ls6 intake mouth to fit a 85 mm tb
SHOULD I CONSIDER CHANGE INJECTORS? I have the stocks
Old Mar 6, 2009 | 12:56 PM
1meantransam's Avatar
i'de say with heads cam it's time to upgrade size. you probably don't need anything big or nasty just something to pump a little more fuel in it. i currently have 40 pound injectors with my setup (90MM h/c 6.0)
Old Mar 6, 2009 | 12:57 PM
also i ment to ask, what motor do you have and what size injectors are on it currently? if it's LS1 then yes to what i said above.
Old Mar 22, 2009 | 12:38 PM
99firehawk's Avatar
Im wondering the same for my application (except going to be adding a 85mm maf and lid as well), I have a 99' as well and they had smaller injectors (26lb), keeping that in mind what does everyone think?
Old Mar 22, 2009 | 02:54 PM
davered00ss's Avatar
Moderator
H/C ls1 should have bigger injectors. SVO 30#'s are good.
Old Mar 22, 2009 | 10:26 PM
syclone74's Avatar
I have h/c combo with long tubes and 3600 stall, 85maf with tpis 90mm ls6 intake and jantzer 92mm throttle body and fast toys lid and I was told to fun 42 pound injectors.
