MAJOR pacesetter longtube header problem!! come in!
Old Mar 20, 2009 | 01:49 AM
Mumbles's Avatar
Originally Posted by ryan00z28camaro
thats what im going to have done tomoroow just a heads up i spoke with pacesetter and they said that if it happens in less then a year they will replace them and you just keep the old headers
Sorry...I just noticed this post. I'm a moron...
Old Mar 20, 2009 | 08:55 AM
udienow's Avatar
Im glad I got the race style.
Old Mar 20, 2009 | 10:11 AM
TheSilverOne's Avatar
Originally Posted by Mumbles
Did you speak with Pacesetter about this? If so, what did they have to say.
This is the second thread in just a couple days with the same topic, and within each thread there are so many people saying, "Hey that happened to me too."
What kinda bullshit is this? I can't believe these headers are doing this. If this happens to mine you better believe the manufacturer will hear about it. This is obviously an issue that needs attention.
If you haven't contacted Pacesetter, PLEASE do and tell them this is a very common problem that apparently needs dealt with.
except when it happens to every header with emissions fittings that are blocked off, regardless of the manufacture. buy race style headers. problem solved.
Old Mar 20, 2009 | 09:42 PM
Black35thz28's Avatar
Originally Posted by TheSilverOne
the front 02 bung is in the collector. the front hole is for the AIR fitting. screw emission headers all together and just buy race ones.
Well it is too late for race headers so everything on the primaries have to be removed/ and welded up if I go non egr air. I think I finally understand, so when people say delete rear o2s its not only because there obsolete once the cat is gone there is also no fittings for them on the y correct?
Old Mar 20, 2009 | 10:00 PM
there are fittings for them. people plug them up with an O2 bung plug. but yes, the rear O2s are useless with no cats.
Old Mar 20, 2009 | 10:08 PM
RacerXLs1's Avatar
I seen this happean to a set of hooker headers too..
Old Mar 20, 2009 | 10:45 PM
Mumbles's Avatar
You're right. That would solve your problem, but not someones problem who, for whatever reason, wants to keep the AIR/EGR. I think all manufacturers of headers need to rethink how these provisions are attached to the primary. Seriously, is there nothing that can be done to reinforce these fittings so this doesn't happen?
Old Mar 21, 2009 | 07:34 PM
My y pipe dosen't have a fitting for rear o2s it's a pacesetter y pipe. So what do I do with the rears ziptie em up and tune out?
Old Mar 21, 2009 | 07:50 PM
Mumbles's Avatar
Unplug them and then ziptie the connector up outta the way...
