about to get pacesetter LTs any tips ?
Use anti seize on your header bolts when you re-install.
If you have big hands like I do you may want to remove your coil packs from one or both sides. If I had been doing mine by myself I wouldn't have been able to get to some of the bolts even though I used a hoist. Luckily I had some buddies that were able to get the ones I couldn't.
Good luck man.
