Slp maf
Old Mar 13, 2009 | 09:28 PM
dnnymorelos's Avatar
Default Slp maf
I'm terrified to put my SLP MAF that I bought new. I have read and been told that it is not a good idea, and that it will just give me problems. I thought it would help out a lil' bit at least. Does anyone here run one?? If so how is it and should I go ahead with the install?? Nothing is wrong wit my sensor just thought every lil' bit helps.
Old Mar 14, 2009 | 06:22 AM
no one?????
Old Mar 14, 2009 | 03:34 PM
sisko85641's Avatar
check these out.
http://www.gmhightechperformance.com...est/index.html
http://www.highperformancepontiac.co..._am/index.html
Old Mar 14, 2009 | 07:39 PM
HMERacing's Avatar
I run one with no problems. I use the stock bellows also. Put it on, the worst case would be that you dont like it and take it back off.
Old Mar 14, 2009 | 11:09 PM
sroach20's Avatar
if you dont like it pull the resistor and have it tuned.
Old Mar 15, 2009 | 03:55 PM
SSnut2K's Avatar
had mine 8 years no problems...
Old Mar 15, 2009 | 03:59 PM
philsblwnz28's Avatar
What does the resistor do?
Old Mar 15, 2009 | 11:03 PM
sroach20's Avatar
https://ls1tech.com/forums/pcm-diagn...-85mm-maf.html
Old Mar 16, 2009 | 03:23 AM
Swift_01_z-28's Avatar
I have an 85mm ftp lid and 85mm slp maf combo with the stock bellows, and have had no problems so far. Had them both on for about 6-7 months now. To get the full effect of the new maf though, you will need a good tune.
