are my injectors big enough?
Old Mar 18, 2009 | 06:33 AM
supergt99's Avatar
Default are my injectors big enough?
car is 2001 z06 with the following mods: livernois stg2 heads, vrx5 cam 236/238 .601/.605 113 LSA, LT headers, ported fast 92mm.
car has stock fuel pump with 30# svo injectors right now. do i need to upgrade before my tune?
Old Mar 18, 2009 | 06:53 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Should be okay. The tuner can tell you what the duty cycle is on the injectors
Old Mar 18, 2009 | 07:08 AM
FormulaZR's Avatar
According to the "calculations" the 30# SVO's @ 43.5 psi would be 34.6# @ 58 psi, and 34.6 psi is enough to support 440-450 flywheel horsepower at an 80% duty cycle. Maybe that helps a little bit.
Old Mar 18, 2009 | 07:58 AM
vsocks1's Avatar
If it were me I would go one step bigger and get the SVO 42# green tops.
Old Mar 18, 2009 | 09:06 AM
TORCHD 02 TA's Avatar
If that was my car, i would get the ford green top 42# injectors.
Just to give you an idea. My car CAM ONLY with stock H/I made 415/378 and my injectors are at 98% duty cycle
So in April/May i am putting in my 42's and getting the car retuned
