Putting in PowerMaster Alternator....pulley question
Old Mar 19, 2009 | 10:33 AM
01 ss vert's Avatar
Default Putting in PowerMaster Alternator....pulley question
The previous owner put in underdrive pullies. the stock 102/105 amp crapped out on me, and I upgraded to a 150 amp PowerMaster. Upon looking, the two alternators are almost identical in pulley sizes.
I measured them both (one on the stock alternator that went out, and the new Powermaster), and the difference in circumference of the two pulleys is .4", or 6%. (approx 6.69" vs 6.28")
Since the new alternator is nearly 50% higher amperage at peak, would you worry about the 6% difference in pulley size? Changing it would be a pain at this point.
Old Mar 19, 2009 | 11:37 AM
Grimes's Avatar
I would not worry at all.
Old Mar 19, 2009 | 12:43 PM
PowerShift408's Avatar
It wouldn't bother me any. Are you running anything that would put additional draw on the charging system (i.e. big stereo system, electric water pump, etc.)?
Old Mar 19, 2009 | 06:37 PM
01 ss vert's Avatar
As of right now, nope.
Gonna be putting on my old NX Kit (remote bottle opener, heater, ect), but no stereo, amp, or anything besides a stock power demand.
Old Mar 19, 2009 | 06:51 PM
You'll be more than fine then.
Old Mar 27, 2009 | 05:32 PM
01 ss vert's Avatar
Well, I still got an issue. The alternator is not charging the battery. The excitor wire is showing 10Volts with the key turned, but the engine off. Is this too low? It's 0 volts with the engine off (as expected), and 10 volts with the key turned.
Old Mar 27, 2009 | 05:36 PM
01 ss vert's Avatar
Any ideas what my issue could be?
