Idling and boiling coolent issues
Old Mar 23, 2009 | 07:13 PM
98zonjuice's Avatar
Default Idling and boiling coolent issues
Installed a 92 FAST intake. Got the coolent crossover pipe and block offs for the back. Got everything put back together, and the car won't idle right, or staying running all the time. Also, the coolent wants to boil after 15-20 minutes. Car doesn't seem to run hot, but I can hear the coolent boiling and then spills over. I ran of with the cap off, so there shouldn' be any air in the system anywhere. Ideas???
Old Mar 23, 2009 | 09:41 PM
SweetS10V8's Avatar
I dont think the FAST has anything to do with it. I have the exact same setup as does basically everyone else with a FAST.
Look at the cooling system for the boiling over. Check for vacuum leaks for idle issues.
Old Mar 23, 2009 | 10:11 PM
LS6427's Avatar
Just because the cap is off doesn't mean there is no air in the system.
Top it off, leave the rad cap off, start the engine......then while its heating up quickly squeeze the top and bottom radiator hoses like you're priming a gas tank line. Do it like 20 times each. Even if it does splash up and out of the rad fil lcap while you're doing it. I did this a few weeks ago and it worked out all the air and the t-stat opened. It would not open while there was air in there and mine to started boiling out the cap.
