Header install
Old Mar 25, 2009 | 11:30 AM
banditz28's Avatar
Default Header install
i will be doing my install in about a week on my 98z i was wondering do i need the o2 extensions? and how long. i deleted my rear o2s so there not a problem. also does anyone have any helpful tips/pics about the install
Old Mar 25, 2009 | 11:34 AM
RedRallyeZ's Avatar
yes you will need O2 ext. remember to get the square type connector. as far as tips go, just get the car as high as you can
Old Mar 25, 2009 | 12:06 PM
chevy8806's Avatar
What i did is use the after cat sensors (because they are longer, same sensors) and use some of the wire from the pre cats to extend it that way. Just an idea
Old Mar 25, 2009 | 03:40 PM
Scammper's Avatar
my Pacesetter headers came with wire, so Im just going to cut and splice to make them as long as I need. Then I have some kevlar heat protect tubing to finish them off...
The sticky at the top of this section has some pretty good install links in it:
https://ls1tech.com/forums/generatio...e-posting.html
(see post #2)
good luck!
Old Mar 26, 2009 | 07:49 AM
02Sweet's Avatar
I just did my first header install not too long ago. For the height of the car you need to get it much higher than you are probably thinking. I was amazed how high the damn thing was. Also if you can get a friend to help you out it makes the install go much easier. Just make sure you remove the plugs first so you don't break them inside and have tough time getting them out
Old Mar 26, 2009 | 05:06 PM
98RedBird's Avatar
(see post #2)
good luck!
Don't splice them. Just do it the right way and buy some extensions... you'll thank yourself in the long run. Trust me.
Old Mar 30, 2009 | 02:09 PM
Scammper's Avatar
You have a bad experience with splices?
I still havent gotten to this part yet... I figure as long as I take my time and soldier them up good, it will be the same as extensions.
Old Mar 30, 2009 | 07:37 PM
tripps's Avatar
Just buy the extensions. After being under the car for as long as you will be with the header install, you won't want to go back under for some o2 sensors!
 Michael S. Palmer
Old Mar 30, 2009 | 07:43 PM
sscamaro1384's Avatar
yeah, get the xtensions like 35 bucks and no worries. Also remove plugs, removing coil packs and cruise control bracket and battery gives more room to work with. Get a 10mm gear wrench-10 bucks well worth it.
