Question about my new Breather....
So this weekend, amongst all the other work I did, I threw on a differnt style breather. Its completely closed, with a 5/8" nipple on the side. The breather has what appears to be a block of foam in it. The inlet isnt fully open, its like a semi circle piece of metal sort of folded in.
My question is...should I be worried about this not vent properly? I dont really see how it wouldnt, but I wanted to check with you guys. My plan was to run a length of hose into the fender area or under the car. Im not sure if I need to vent the other cover now or not. Like I said, my gut says Im ok...but Ive been wrong before.
Thoughts?
J.
You need to upgrade a breather with a catch can or what I did was the old school evac system out of each valve cover down to the exhaust.
http://cgi.ebay.com/ebaymotors/CRANK...QQcmdZViewItem
You have to install them after the muffler, not use their breather caps, but install the hose to the valve cover pipe.
Just one way !
