QTP Header Size
Old Oct 23, 2003 | 08:55 AM
SapphireHawk's Avatar
Default QTP Header Size
I know this topic has been beat to death , but I searched and haven't found a good answer.
I am getting a set of QTP Headers in the next month or so. Right now my car is stock, but I am planning on Stage II LS6 Heads (Patriot Performance), Medium Cam, and a 100 Wet Shot after it is all said and done.
I was originally going to pick up a set of 1 3/4 High Velocity headers new. But if I had the oportunity to get a set of 1 7/8 headers used for cheap, would it hurt performance in the begining, if so how much compared to the 1 3/4. Would I gain it back after the heads/cam?
Does anyone have any evidence of this, or is it all theoretical?
Old Oct 29, 2003 | 08:33 PM
WILWAXU's Avatar
to the top
Old Oct 30, 2003 | 01:09 AM
Jeffs99SS's Avatar
For stock cubes, most seem to agree that 1 3/4" is the way to go, even with heads and cam. I think the 1 7/8 would best be saved for big cube guys, unless you plan on spinning the motor extremely high. The smaller primaries should also leave you with much more low end torque than the larger pipes.
Jeff
Old Oct 30, 2003 | 07:47 AM
ulySSes's Avatar
Ah, I needed an answer to that too.
Old Oct 30, 2003 | 08:50 AM
Old SStroker's Avatar
Check out curent Car Craft 12/03 issue now on the newsstands for the article on pg. 62 by Jim McFarland. This should help you make your decision.
Old Oct 30, 2003 | 03:16 PM
BigPlanTransAm's Avatar
not all of us get that magazine
