possible FAST TB fix
Old Apr 5, 2009 | 11:59 AM
superchargedgp's Avatar
Default possible FAST TB fix
i have fast 78mm TB it had a common sticking issue that most FAST Tb's have. it wasn't bad but i was getting annoyed by it.
so i took it all apart including the shaft out of the body, to see if by adjusting the blade it would solve the problem.
what i found out was that whoever put it together HE-MAN the screws that hold the blade to the shaft. the shaft is aluminum.
when i took it all apart i noticed the shaft being a little bent. which caused the TB to stick.
took the shaft and bent it back sightly using a glass table as a guide to keep it straight
i put it all together making sure not to apply too much pressure on the screws while tightening them down and put a little locktite on the screws.
put it back on the car and it seems fine. the pedal moves smoother and the TPS values have smooth increase.
so i do believe that the reason FAST 78 ans FAST 90 TB's stick is the numb nuts who puts them together presses too hard on the bolts
and slightly bends the shaft.
hopefully this helps some of you that have the same problem
Old Apr 5, 2009 | 02:37 PM
thunderstruck507's Avatar
might have to give that a shot!
Old Apr 6, 2009 | 05:29 AM
GA95DCMSS's Avatar
And I Just sold mine!!!! Good find though!
Old Jun 22, 2009 | 03:33 PM
3 months later and still havent stuck once, this is the fix!
Old Jun 23, 2009 | 05:55 AM
toadzq8's Avatar
Thanks superchargedgp, I am having problems with my fast sticking when it gets hot looks like I need to take it apart and check the shaft.
Old Aug 16, 2009 | 12:33 AM
Sweetred95ta's Avatar
I'm glad I found this thread. I had already pulled my FAST 90 TB apart and couldn't find anything wrong (stuck open all the time even with an extra return spring). After I read this today, I pulled the TB off and checked the shaft to see how true it was. I didn't notice it until I put the shaft next to a square, but it was definitely bent. So, I straightened it out, greased the bearings up, added one more turn to the spring and drove it all night tonight without one single problem with it sticking. It was so much easier (and smoother) driving it around. I just wanted to say thanks.
