stock ls1 TB and LQ9 question???
Old Apr 6, 2009 | 08:24 AM
sscamaroburn02's Avatar
Default stock ls1 TB and LQ9 question???
Will a stock LS1 Throttle Body be a direct replacement for a DBW TB in a 03' LQ9?? I know these engines are iron blocks and have drive by wires.
What all would be needed if anything???
Thanks
Old Apr 6, 2009 | 08:49 AM
12secSS's Avatar
It will bolt right up, so long as the TB flange has three bolts (in a triangular pattern).
Edit: Why are you using a truck intake on your F-body? Just use your LS6 intake, it will bolt right on to the 317 heads. Unless this question is for a different application?
