Header swap
Old Apr 6, 2009 | 04:45 PM
MeanGreen's Avatar
Default Header swap
Would changing from ceramic coated Pacesetter LT's to either Kooks or QTP's make a diffrence on HP and most important at the track with my set-up? I have all the bolt-ons.
Old Apr 6, 2009 | 04:51 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Probably not enough to justify the cost - I'm in the middle of swapping my Kooks 1-3/4" for Kooks 1-7/8" primaries, but I'm doing it planning on more cubes in the future.
Old Apr 7, 2009 | 10:56 AM
MeanGreen's Avatar
That is what I was wondering. Spending money on QTP or Kooks to only see a .10 gain on the 1/4 mile I think won't be wort it. Or worst, run the same damn times.
Old Apr 7, 2009 | 03:03 PM
99TransAmLS16Spd's Avatar
Some swear by the 1 7/8s for every ls motor. But in my opinion, based off of the specs in your sig, put the money elsewhere for now. You will see more bang for your buck. Down the road, after you've done a cam/heads etc, then consider the larger header. They should also net you a larger gain at that point.
Old Apr 7, 2009 | 03:39 PM
Magic Man's Avatar
You might think down the road as stated but for your car now one set of headers is about as good as another.
