how to replace powersteering?
Old Apr 11, 2009 | 12:29 PM
2002redhawk's Avatar
Default how to replace powersteering?
I need to replace my powersteering and was hoping that someone had a a step by step guide to change it out. Any help would be great!
thanks
mike
Old Apr 11, 2009 | 01:16 PM
Soul TKR's Avatar
basically just take your belts off, and get a pulley puller tool from autozone, checkers, napa, etc... You'll need to pull the power steering pulley in order to remove the pump...
Old Apr 11, 2009 | 01:31 PM
I know you hafta pull the pulley. . But theres no way that you can get the puller int here to get hte pulley off. The pulleys like 10inchs long. Do i hafta take the radiator off/unbolt the engine and lift it up?
Old Apr 11, 2009 | 02:11 PM
Vicinity's Avatar
No, but you may need to drain the radiator and move some piping for room to work. No lifting is involved, or at least is not necessary.
Old Apr 11, 2009 | 02:42 PM
i must have the wrong powersteering pulley puller then. Its 11inchs long. Theres no way it'd work. I have the radi drained, and the hose pulled off. at this point it'd be easier to just drop the radi, how do i go about this?? Thanks for the help guys.
Old Apr 11, 2009 | 03:12 PM
Soul TKR's Avatar
yea i ended up having to pull my radiator because the tool was too long also... but my radiator is huge so I didn't know if you would run into the same problem. Just start disconnecting wires/hoses and the radiator should just lift right out
