Motor mount and jacking points??
Old Apr 12, 2009 | 12:22 PM
Erikz 28's Avatar
Default Motor mount and jacking points??
Do you havve to remove the a/c to change the passenger side mount or is there an easier way... I did the driver side mount which wasnt too much of a PITA. Also this seems like a stupid question but, jacking the car up on the K member in the center doesnt hurt it, does it?? Or the lower A-arm the side nearest to the engine? thanks....
Old Apr 12, 2009 | 01:01 PM
mook99ta's Avatar
Lower control arm side is okay, I did mine once on the K-member and it started to dent so I stopped, I have heard other people jackin by the K-memeber but I don't. When I did my mounts I had to remove the AC just made it a whole hell of alot easier.
Old Apr 12, 2009 | 01:04 PM
Erikz 28's Avatar
thanks man.... did you have to undo any a/c lines or just remove the belt and bolts holding it on and swing it out of the way?
Old Apr 12, 2009 | 02:12 PM
blkbird's Avatar
I took the a/c and mounting bracket off to make it easier to get the bolt out.
Old Apr 12, 2009 | 02:30 PM
01ssreda4's Avatar
me too, i took an old wire coat hanger and looped it around the radiator support to hold the compressor up..
Old Apr 12, 2009 | 07:46 PM
mook99ta's Avatar
I pulled it out and just had it recharged
