BBK Throttle Body Question?
Old Apr 12, 2009 | 05:52 PM
BadgeZ28's Avatar
Default BBK Throttle Body Question?
I picked up a used 80mm BBK for my boosted motor thinking its heavier build would be an advantage over the stocker. It comes with the throttle body, a gasket and spacer/reducer. The throttle body is the same thickness as the stock one. Right now my plumbing from the supercharger does not allow room for the spacer/reducer. So, the question is, can I just run the BBK throttle body minus spacer? I am thinking the sold surface of the spacer seals the back ports of the TB and it won't work without it.
Old Apr 12, 2009 | 06:12 PM
jsteele90's Avatar
i used to have one and didnt run the spacer. worked fine
Old Apr 12, 2009 | 06:27 PM
BadgeZ28's Avatar
jsteele, did you just attach it using the stock O ring gaskets or insert the flat gasket provided in the kit?
Old Apr 12, 2009 | 08:27 PM
jsteele90's Avatar
no gasket either just the oem one in the intake
Old Jul 8, 2009 | 09:57 PM
99RedTa6spd's Avatar
hey i was thinking of getting the bbk throttle body could you tell a difference at all and do you need to tune after?
Old Jul 9, 2009 | 10:34 AM
BadgeZ28's Avatar
You don't need a tune. Mine was used and the idle screw needed adjusting to lower the idle speed. BBK sets a idle at the factory so if you buy a new one, just install and go.
Old Jul 9, 2009 | 12:14 PM
Striker's Avatar
I also heard that the TB spacer makes a lil whistling sound, this true?
Old Jul 9, 2009 | 12:23 PM
BadgeZ28's Avatar
I can't run it. I have a supercharger and the piping is tight
