Is it possible to repair leaking power steering pump?
Old Apr 13, 2009 | 06:33 PM
Vetal's Avatar
Default Is it possible to repair leaking power steering pump?
As title says - is it possible? Where does it leak?
Old Apr 13, 2009 | 08:54 PM
Speedsaurus's Avatar
I suppose it would depend on where its leaking from. Mine had been leaking and the Dealership doing the work on my car had said they repaired it by replacing the pulley shaft I think. (was a while ago). Well it still leaked after and fried my alternator. So I tear into it to replace alt. and find that the one tube running into side of the PS resevoir had a bad O-Ring. Replaced that and has been fine since. (other than the occasional burping fluid past the cap) Hope this can help a little bit, O-ring is cheap fix so something to look for.
Old Apr 13, 2009 | 09:16 PM
Vetal's Avatar
This really sounds like an easy fix
Old Apr 13, 2009 | 09:20 PM
Killer_Z's Avatar
duct tape fixes lots of things, that and crazy glue. lol. but yeah it depends on how the leak is. could be O-rings or pulley. just depends.
Old Apr 14, 2009 | 01:41 AM
Vetal's Avatar
if it's "pulley", what does it mean?
Old Apr 14, 2009 | 08:27 AM
ShortChevy's Avatar
Not the pulley but I'm sure there is a seal that the shaft goes through.
