spark plug
Old Apr 19, 2009 | 10:36 PM
99huggerorangeZ's Avatar
Default spark plug
is the stock spark plug gap? .060?
Old Apr 19, 2009 | 10:53 PM
LS12Fast4U's Avatar
Yes. You should be fine with .060
Old Apr 20, 2009 | 11:18 AM
witry's Avatar
depends on mods stock id go with .055 to .060
Old Apr 20, 2009 | 07:50 PM
joecar's Avatar
GM has revised it to 0.040" a few years ago.
Old Apr 20, 2009 | 11:44 PM
do you have the service bulletin?
Old Apr 21, 2009 | 12:55 AM
OhTwo's Avatar
The factory plugs from my 2002 TA were gapped at .055"
Old Apr 21, 2009 | 10:50 AM
joecar's Avatar
Default This TSB supercedes 03-06-04-060A...
INFORMATION
Bulletin No.: 03-06-04-060B
Date: July 30 2008
Subject:
Information on New Spark Plugs and Gapping
Attention: Please disregard the Set Gap Per Vehicle Specification statement on the side of an ACOelco(R) Iridium Spark Plug Box. The statement will be removed from the boxes in the future.
Supercede:
This bulletin is being revised to add the Chevrolet SSR and the 2005 Pontiac GTO. Please discard Corporate Bulletin Number 03-06-04-060A (Section 06 - Engine/Propulsion System).
^ A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design the gap of the spark plug has also changed.
^ The new spark plug P/N 12571164 with AC Delco P/N 41-985 is gapped to 1.01 mm (0.040 in) when the spark plug is made.
Notice: The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
