ls1 intake rear plug
Old Apr 20, 2009 | 08:59 PM
v8bug's Avatar
Default ls1 intake rear plug
I am swapping in a standard ls1 intake for height reasons (from the truck intake)
In the rear of the intake there is a plug where the map sensor mounts and a vacuum line for the brakes. This plug seems to be inserted and locked into the rear of the intake.
My problem, or worry, is that i can grab the plug/fitting and rotate it in the intake about 1/8" clockwise/Cclockwise.
So my question is, is this normal? It is not easy to turn, but it does turn. Will this leak?, the motor will be seeing boost too
thanks,
Matt
