Help with plug wires..
Old Oct 29, 2003 | 09:36 AM
RICE ETR's Avatar
Turbo Addict
Default Help with plug wires..
I need to slightly move my coil packs and run all the driver side wires up front towards the power steering pump, down the front of the engine approx through the head gasket area then down around the underside of the headers and to each of the four plugs with a 90 degree boot for added clearance.
I searched and found guys using the custom wire sets for Lt1's.... summit has the MSD 8.5 mm set with the 90 degree boots ~ $70.... question is will that much plug wire hurt things on these cars since they are not the same length like they are stock? How many feet of wire do they give you?
Sorry for the silly questions... just wanna make sure though.
Thanks,
-Jarrod
Old Oct 29, 2003 | 06:33 PM
RICE ETR's Avatar
Turbo Addict
anyone?
Thanks
