starter hookup?
Old Apr 27, 2009 | 08:05 AM
Steve Gunn's Avatar
Default starter hookup?
Hi Guys,
There is a small cable with an eye that I hooked up to the small terminal, a large keyed eye that obviously went to the large terminal, then there is another large one... does that go on top of the other or is that a ground to the block?
Thanks!
Old Apr 27, 2009 | 09:54 AM
NW-99SS's Avatar
Only two wires to connect mine - did it yesterday
Old Apr 27, 2009 | 10:11 AM
Steve Gunn's Avatar
Thanks.
I just put the motor back in and out of that lead of the harness, there is a third. Can someone verify this is a ground? If so, where on the block would this attatch?
There is a hole at the rear unused motor mount boss.... hmmmm.
Thank you!
Old Apr 27, 2009 | 01:30 PM
sroach20's Avatar
what color is the wire?
Old Apr 27, 2009 | 02:14 PM
NonGoggleGuy's Avatar
If it's a large black wire with an uninsulated crimped lug on it, it is a ground.
Old Apr 28, 2009 | 07:35 AM
Steve Gunn's Avatar
Thanks! That's it!
