Sensor above Tp sensor
Old Apr 28, 2009 | 05:30 PM
Zerokube's Avatar
Default Sensor above Tp sensor
what is that? im throwing the code for low signal but not for the tp sensor, its something to do with the pedal i believe. anyone?
Old Apr 28, 2009 | 05:42 PM
DaddySS's Avatar
The unit above the TPS is the idle valve - what's the code, question, symptom?
Old Apr 28, 2009 | 06:06 PM
Zerokube's Avatar
My friend at a chevy dealership plugged in his code scanner and it said skip shift not read (unplugged it and putting in resonator) and that there is a low signal from pedal position something, i cant remember the exact term but he said since there is a tp sensor and another one around the actual pedal of the car, that its not getting a signal and that's why the car is sluggish.
Old Apr 28, 2009 | 09:36 PM
sroach20's Avatar
pedal position sensor? are you dealing with a dbw vehicle?
