PS Pump Pully Removal
Old Apr 28, 2009 | 10:26 PM
Low02's Avatar
Default PS Pump Pully Removal
I rented the Autozone puller for this, has anyone ever used it? The stud that screws into the pump has the pulling attachment on it, when you but it up with the front of the pump and try to put the two half's that pull the pulley the wont fit. I took it back off and the two half's only have enough room to fit the attachment only. There is another stud in the kit with a less thick attachment that looks to be the one that would work, but the stud that screws into the pump is way to big. There's no way to make that attachment fit on the stud that fits the pump. Will this puller not work? Any help is greatly appreciated! Thanks, Eric.
Old Apr 28, 2009 | 11:29 PM
TheSilverOne's Avatar
make sure you got a complete kit. when i rented it, they had to combine 3 partial kits to equal 1 full kit.
