Fast throttle body !!
Old Apr 29, 2009 | 03:39 AM
PONTIAC SLP's Avatar
Default Fast throttle body !!
Hi , when i installed fast t/b there are two problems
the first prb the idle is 2000RPM !! the RPM is playing from 1000 to 3000 RPM
the second problem when i rev the throttle body still opened , what can i do to resolve this problem ?
Old Apr 29, 2009 | 06:39 AM
SweetS10V8's Avatar
Is it a 90mm?
Old Apr 29, 2009 | 06:42 AM
deelong4002's Avatar
From what i understand, FAST throttle bodies have troubles with sticking. I wouldnt be suprised if your idle was high, but since its surging up and down, it sounds like you have a vacuum leak somewhere. Search around on here, im pretty sure there is a way to fix the sticking problem with another spring or something
Old Apr 29, 2009 | 07:14 AM
SweetS10V8's Avatar
Common misconception, FAST 90mm thorttle bodies had an issue with sticking. Not the 92mm, its a total redesign.
Old Apr 29, 2009 | 03:31 PM
Originally Posted by SweetS10V8
Is it a 90mm?
yep
how can i check if there are a vacuum leaks ?
