How to fix bangin y pipe?
Old May 2, 2009 | 11:20 AM
1gt2nv's Avatar
Default How to fix bangin y pipe?
My wife and I installed my headers and ory last weekend! Yes, my wife did alot of work. Well we didn't replace the mounts. I know, bad idea. So now the y pipe hits the car. How could I fix this? Could I have a rod welded in there to keep the pipe from hitting? Not sure if it would bend or break because of the motor moving. Is there a hanger I can by to put in there? Any help would be great. The car sounds awesome with the headers, ory and lm1 cat back!!!
Old May 2, 2009 | 12:06 PM
TheSilverOne's Avatar
replace the motor mounts
Siphon's Avatar
I had the same problem. To fix this, I installed solid motor mounts. There is now no movement at all on the exhaust pipes or engine. You might be able to get a similar outcome by installing poly motor mounts, if you are afraid to go solid.
I have solid mounts on my daily driver. No problems. No aggravation. Don't believe all the "you won't be able to stand the vibrations" bullshit.
Old May 2, 2009 | 12:10 PM
bobbyd's Avatar
you can get a mufflex bumpstop hanger or you can go to a parts store get some hose and some 3" clamps and put them between the ypipe and the floor where the ypipe hits.
thats what I did on my car and many others have done the same.
might not be the best method but it works
Old May 2, 2009 | 03:12 PM
Badguy7's Avatar
^^ yeaa do what he said, pretty simple fix. instead of having to go back in there and replace the motor mounts. my y pipe banged when i had the stock exhaust. once i changed it to the LM2, the banging was gone. i guess my motor mounts were still good.....
Old May 2, 2009 | 04:04 PM
c0ncEpT's Avatar
You could even use a piece of heater hose and a hose clamp but thats only a band aide. The only way to really cure this problem is do motor mounts.
Old May 2, 2009 | 07:55 PM
1gt2nv's Avatar
[QUOTE=bobbyd;11530724]you can get a mufflex bumpstop hanger or you can go to a parts store get some hose and some 3" clamps and put them between the ypipe and the floor where the ypipe hits.
Where can I get the mufflex bumpstop hangers? Thanks.
Old May 2, 2009 | 08:21 PM
1gt2nv's Avatar
How many bumpstops should I order and where do you mount them?
Old May 2, 2009 | 08:45 PM
nj02vette's Avatar
[QUOTE=1gt2nv;11532446]
from Mufflex, in Trenton NJ.
Google is your friend.
Old May 2, 2009 | 09:05 PM
Sharpe's Avatar
Poly motor mounts here, but I've not got it back from the shop yet to know if it fixed the problem.
Old May 2, 2009 | 10:42 PM
TORCHD 02 TA's Avatar
didn't read any of the replies. But to fix the banging y pipe, you install Poly Motor mounts
Old May 3, 2009 | 02:52 AM
shaun's Avatar
i had the same problem and i baught the mufflex y pipe hanger and it dident work to good then i dealt with it for a wile.
i also did the heater hose and clamp about a week ago and that worked better than the mufflex piece.
Old May 3, 2009 | 10:27 AM
adam02gt's Avatar
Care to explain a little bit more?
Old May 3, 2009 | 10:36 AM
john563's Avatar
I shoved an old spring between mine and secured with clamps and it worked..Later my friend re installed it with out the spring ,clamps and got it not to bang..This is with hedman headers..When I switched to hooker 1 7/8 I put in motor mounts..Did not want to take a chance with the bigger headers hititin the k memeber
Old May 3, 2009 | 10:37 AM
slayerized6's Avatar
thunder racing sells bumpstop hangers
Old May 3, 2009 | 10:41 AM
Slvr00Bird's Avatar
BFH Mod!!!
Old May 3, 2009 | 11:12 AM
bobbyd's Avatar
aight heres what I did.
1. went to advance auto parts and bough 2feet of 3/4 heater hose. (you dont need that much i had about 1 feet left after but just incase)
2. i bough (4) 3" or 3-1/2" clamps (again this may vary depending in how many locations your ypipe is banging)
3. I cut some 3"-4" pieces of heater hose and then I slided them in into the clamp (look at the pic at the bottom but note that the clamp in the picture is not a 3" and I didnt cut the hose at all I just took that pic quick to show what it kinda will look like.
4. put the clamps with hose in between the top of the ypipe and the floorboards. then tighten up the clamp with a flat head screw driver.
Old May 3, 2009 | 11:21 AM
1gt2nv's Avatar
Thanks for all the help and tips guys! I ordered a 3'' bumpstop from ws-6store. Should I mount it on the drivers side? I think thats where it's hitting.
Old May 3, 2009 | 11:28 AM
bobbyd's Avatar
turn on your car and see where the ypipe is banging if it doesnt bang when you have it idling get your wife or someone to put it in drive an look to see if you see where its hitting.
but yea more than likely its always under the drivers side.
Old May 3, 2009 | 11:40 AM
1gt2nv's Avatar
^ It only does it in rev. I'll have my wife help out. I'll just lay down and look to see where it hits. I think I already know. Thanks for the help!!
