Pulley Question 98 LS1----
Old May 4, 2009 | 09:05 AM
TomM's Avatar
Default Pulley Question 98 LS1----
Not going to run power steering, does anyone make an idler to put in place of this pump...
thanks,
T.
Old May 4, 2009 | 10:58 AM
mook99ta's Avatar
just get a shorter belt and a adjustable idler like a katech or comp or speed inc.
Old May 4, 2009 | 01:57 PM
TomM's Avatar
I was looking for a direct bolt in replacement, any websites that have these conversions?
T,
Old May 4, 2009 | 05:02 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I haven't saw one for a LS1.
FYI: I took the PS and the lower idler pulley(inbetween alternator and crank pulley) off my car and I ended up running a 51.5" belt with a Powerbond underdrive pulley
Old May 4, 2009 | 07:10 PM
TomM's Avatar
Is your alt. below the PS pump or up top? I am thinking about just looping the PS pump and running it for now, just to get it going. I also spoke to Katec, and they can build one for 200, but eventually I will just install a front drive pulley system with some bling......
T
Old May 5, 2009 | 02:04 AM
Z28/2002's Avatar
Mine is on the bottom
I cut the metal lines on the rack and looped them with a piece of 3/8 hose
Old May 5, 2009 | 07:12 AM
TomM's Avatar
Excellent, thanks for the tip, sounds like the way to go......
T,
