11.8 Volts WOT?
Having a issues where i get random MAF/VAF codes,02 sensor codes and once in a while misfire codes, changed those out numerous times and now under scanning with HP tuners i am seeing tons of knock and slightly down on performance(from the knock). I am wondering if the 11.8@WOT is causing enough loss of voltage to hurt the fuel pump which is causing knock and general electronics to go a it haywire and throw codes? The car is pretty much stock, walbro pump, lid, exhaust.... The battery isnt new but it does crank and see 12 volts plus and running i am only getting 12.5 at idle, maybe alternator is bad though its does give enough juice to run everything and not kill the battery...looking for thoughts before i go and change the alternator and buy a battery...
