Ported TB or ASP Pulleys?
If I go with the TB, which one should I get?
If I go with an alternator pulley, where should I get it and will it work ok with my amp and subwoofers?
Any thoughts on the decision would be appreciated.
If you go with an ASP pulley, all you need is a crank pulley.
Both should net around the same RWHP
The pulleys wil give you a noticeable increase at all rpms, whereas the ported throttle body is more for top-end gain.
The ASP pulley yields consistant gains. The TB shines when you have a lot of breathing mods... (headers, intake, cam, heads, etc...)
The guy who only gained a few hp from his pulley and ORP could probably have used a tune after he removed his cats, don't let that sway you.
Tommy
