MAC midlengths, i have a few questions
Old Nov 3, 2003 | 08:41 PM
WS6FirebirdTA00's Avatar
Default MAC midlengths, i have a few questions
ok for one i dont wanna spend all that money on the full lengths. i just wanna know about how much power i can gain from this and how much less it is than full lengths. how is the coating on these headers? is it ceramic? and will it get cruddy looking? how is the ground clearance? how about the sound? and fit? and is there any way to order them without emission provisions on them? thanks guys
Old Nov 3, 2003 | 09:29 PM
anyone even use macs? lol
Old Nov 3, 2003 | 10:06 PM
untchabl's Avatar
Pacesetter L/T's with O/R Y are about the same price as the Mac's with the O/R Y. I'm planning on going ahead and getting the Pacesetter's. Heard lots of good reviews about them. Haven't heard much about the Mac's.
Old Nov 3, 2003 | 10:43 PM
mcflyz28's Avatar
coating on the MACS is extra.
Old Nov 3, 2003 | 10:49 PM
Cal's Avatar
Cal
You get about 25 hp from long tubes; that's 20 hp more than Macs. Going through a header install for 5 hp wouldn't be worth it to me, especially knowing how much better I could have done with long tubes.
Old Nov 3, 2003 | 11:17 PM
jrp's Avatar
jrp
SN95 Director
werd, if your on a budget you can get Pacesetters LT's coated and O/R Y for under 500.
macs arent worth it, go as SSaction (i think). his macs killed him on the dyno with his x1 cam and bolt ons.
Old Nov 4, 2003 | 03:21 AM
RyanJ's Avatar
SSU Moderator
fyi....used macs are like $200. plus most people get more than 5hp....provided they drop the cats too.
Old Nov 4, 2003 | 06:48 AM
who has the best deal for pace setters
Old Nov 4, 2003 | 07:00 AM
i talked to someone that sells the coated macs and pipe for 530. but ill double check. and 5hp?? people with shorties get more than this i have seen.
Old Nov 4, 2003 | 07:06 AM
nvm i found them 464.98 coated and with ypipe. that was from texas speed. is that coating ceramic? and how about the ground clearance wiht these headers?
Old Nov 4, 2003 | 07:25 AM
Z-Rated's Avatar
read my reply to this thread, and open the link and check out my thoughts of macs to hookers. read this BTW people compare hookers to pacesetters so the gains should be about the same.
Old Nov 4, 2003 | 07:51 AM
Hardtop's Avatar
I'm wondering where you came up with the Macs only giving you 5 more Hp then stock. I bought my Macs before Hookers or Jet Hots were available. They are still on my car. They may give up a bit of low and mid range power to long tubes, but give up very little, if any up top. Some have made more peak power with Macs then with long tubes. I have a custom y-pipe with a Flowmaster collector with mine. ! ball connectors, 3" y-pipe. Macs haven't slowed my car down too much.
Bruce
Old Nov 4, 2003 | 10:45 AM
Bad30th's Avatar
I'm making 410rwhp/415rwtq through Mac midlengths. What's all this about a 5hp increase over stock exhaust, and a 20rwhp gain with LTs ?
Bad30th
Old Nov 4, 2003 | 11:04 AM
equandt's Avatar
Macs are a good economical header option for our cars. They have been around for quite a while now and they will give you 15-20 rwhp over stock manifolds.
Granted the Mac cats suck, but there are ways around that if you have to have cats.
The Mac coating is also less than desirable when compared to the Jet-hot coating but you can have Macs Jet-hot coated if you want.
You can make Macs as good or bad as you want. They are a good and economical option if you want to keep your car internally stock. LT's will give you better gains on a cammed car.
I wouldn't bash the Macs. They are what they are.
Old Nov 4, 2003 | 02:33 PM
Kylekay's Avatar
What makes the Mac cats suck?
I have Macs w/cat and have been seeing a loss of power over the last 2 years, I'm guessing I've lost 40rwhp its hard to tell because of the new cam. Do the Mac cats plug up?
Old Nov 4, 2003 | 02:36 PM
onebadz's Avatar
Will you see a decrease in low end torque over stock manifolds if you go to macs?
Old Nov 4, 2003 | 02:48 PM
guys check out this link, i have some questions there can your answer them, or attemt to please?
https://ls1tech.com/forums/showthrea...506#post813506
Old Nov 4, 2003 | 02:53 PM
equandt's Avatar
The Mac cats just don't flow very well. FLP or QTP (or one of the Mac competitors) did a flow test on all the cats available and found that the Mac cats flowed the worst of the bunch tested. The Mac cats since then have been continously bashed. I may have mis-spoke when I said the Mac cats suck. I should have stated that they don't flow as well as other cats that are currently available.
Macs still are a good economical choice, you just have to realize that you get what you pay for.
Old Nov 4, 2003 | 11:30 PM
Goober's Avatar
Macs don't gain any power LMAO. FYI, I dynoed 368/378 with macs and duals. Then with a baby cam I did 402/378.
Old Nov 5, 2003 | 08:36 AM
Tally TransAm's Avatar
i gained 21 hp and 20 ftlbs with macs, near or equal to that under the curve all the way across
i really doubt LT's would have been much better
people just want to justify to themselves spending what they did for they lt so they say things like macs will only give you 5hp though it is far from the truth
