Throttle Body Blade - How to fill the hole...
Old May 22, 2009 | 11:44 PM
Soul TKR's Avatar
Red face Throttle Body Blade - How to fill the hole...
Hey guys... I gotta figure out some way to either fill the hole on my throttle body blade, or get a new blade without the hole in it.
some guys have suggested JB Weld etc... I'm just not too thrilled about putting something "hard" in there in case it were to ever come off and go into my engine...
I know I can't be the first to need to do something like this. Any ideas?
Old May 23, 2009 | 12:17 AM
hitmanws6's Avatar
get it welded shut? for something that small a shop shouldnt charge for it
Old May 23, 2009 | 12:25 AM
LS1Silverado05's Avatar
No way I would JB it... Have someone weld it shut if need be... but why does it need to be closed? Did someone drill a huge one or what?...
Old May 23, 2009 | 04:04 AM
transwiz's Avatar
Like the post above says,Was it drilled out?That hole is there for a reason.Why do you want to fill it? You can have the hole welded.I have had a hole someone drilled on one my bbk tb welded up before.
_________________________
2000 t/a ws6
Old May 23, 2009 | 04:57 AM
Soul TKR's Avatar
yea... the hole was drilled too large, and after the tune has been modified, the hole is no longer needed.... with the hole in there, as is, it idles at like 2000
for the time being i've put a piece of gorilla tape over it and it's doing fine. But I don't wanna drive it too much like that, as one piece almost got sucked in already because of the heat... so until i can fix it correctly it's gonna stay parked for a bit...
Old May 23, 2009 | 07:45 AM
DaveX's Avatar
You could try solder. It's not as very hard so if it did come loose it wouldn't be as bad as a piece of jb weld or something.
Old May 23, 2009 | 04:02 PM
Soul TKR's Avatar
i might try the weld idea... i've got a buddy with a welder so...
Old May 23, 2009 | 06:35 PM
01ssreda4's Avatar
thats an alternative. dont let the guy welding it go crazy bc heat WILL distort the blade. Solder on the other hand wont distort it.
Old May 23, 2009 | 06:43 PM
crzytown69's Avatar
I say find a small screw or make sure you have a damn good welder
Old May 23, 2009 | 07:13 PM
blkbird's Avatar
I had drilled out my TB blade a bit, but the tuner adjusted for it and my car idles fine at 750rpm.
Old May 24, 2009 | 01:08 AM
thndrracer's Avatar
rivet?
Old May 24, 2009 | 02:11 AM
Soul TKR's Avatar
bet your hole isn't the size of a pencil though
wonder if any of the "porting" guys on here have any blade "cores" lying around...? who does that kinda thing on here...?
Old May 24, 2009 | 02:57 AM
brianfromhawaii's Avatar
I suggest you solder it.
Old May 24, 2009 | 03:17 AM
98TA6.0's Avatar
it would be a great time to go to a 92/92 now then huh? lol. why dont you just find used one for cheap? they are easy to come by.
Old May 24, 2009 | 05:52 AM
Soul TKR's Avatar
pshhh....92/92
I'm thinkin 96/96
just need about 2k first
Old May 24, 2009 | 07:04 AM
98TA6.0's Avatar
well i spent roughly 1400 on my TSP ported 92mm with a PTM 95mm TB. why dont you just rivet a plate over the hole and drill a new one in that plate? you can secure it rather easily and if you buck them correctly it should last forever. it may create a small bit of turbulence but who cares, at least it will idle.
Old May 24, 2009 | 08:31 AM
bonestock99's Avatar
Weld it already!!!!
