Alternator Bracket
Old May 23, 2009 | 05:30 PM
LS1ROPER's Avatar
Default Alternator Bracket
Putting the front accessories on my 408 project get to the alternator bracket there is only two bolt for a bracket that needs four holes. Bracket coming off a 99 LS1 going to a 06 6.0 block I thought everything was transferable? Going to have to drill and tap one hole in the block but there is no provision to drill a hole close to the front cover below the tension pulley on the alternator
Old May 23, 2009 | 06:44 PM
DVS99TRANS's Avatar
Your going to have to tap it, I am doing it tomorrow on mine. I found this write up after researching it.https://ls1tech.com/forums/generatio...snt-match.html
