Just cut my true duals
Old May 27, 2009 | 01:17 PM
jasycz28's Avatar
Default Just cut my true duals
My true duals went under my rear end and when I was changing my rear shocks and springs my rear end couldn't lower far enough to get my springs out so I cut my exhaust off about 6in after the mufflers. Does it matter if I don't have turn downs? Will it harm my car at all? It should only be about a month before I put my new headers and exhaust on do you think I will have any problems?
Old May 27, 2009 | 01:36 PM
shaun's Avatar
only thing it might do is make your car vibrate/resonate more and you might get a little more fumes in the car.
Old May 27, 2009 | 01:37 PM
z28hustle's Avatar
they should be cut off before the rear tires anyway..
Old May 27, 2009 | 01:40 PM
Blown427conv's Avatar
Won't hurt the car but will fume you out a little. Also makes the under side rear of the car black and sooty after a while.
Old May 27, 2009 | 01:57 PM
jasycz28's Avatar
cool... should only be this way for about a month anyway. Full exhaust sitting in the garage just waiting to be installed.
Old May 27, 2009 | 08:12 PM
integraxtc's Avatar
buy some turndowns at autozone, and clamp them on.
Just to avoid soot.
Now, if you don't really drive it, then might as well leave it.
