Need help with motor mount and headers
Old May 27, 2009 | 10:28 PM
97ta383's Avatar
Default Need help with motor mount and headers
Ok so i have lpp lt on my 02 t/a a4 and i keep haveing problems with the drive side header hiting the motor mount stand i adjusted them and its not has bad but its still there someone told me try poly mounts but i dont see how that would help because they would still be resting on the stand and i dont want solid mounts but i saw this on ws6store
http://www.ws6project.com/user_stor/...oducts_id=1761
they are spohn lightweight lsx bushing stands and i was wondering if they woul give me the extra room i need and i would get poly mounts with them as well. What do you guys think anyone have them or seen them? Thanks for the help
Old May 27, 2009 | 11:08 PM
metalmechanic's Avatar
u should get solids
Attached Thumbnails Need help with motor mount and headers-10-30-08_1454.jpg   Need help with motor mount and headers-10-30-08_1455.jpg   Need help with motor mount and headers-10-30-08_1507.jpg
Old May 27, 2009 | 11:20 PM
97ta383's Avatar
i have talked to a few people about solid mounts and they all said it wouldnt be comfortable for a daily driver and that i would also need to replace the trans mount as well
Old May 28, 2009 | 12:49 AM
CayenneRedV6's Avatar
I had the same problem your having. I had to re-adjust them and dimple the primary that was making contact. Heat it up with a torch and hit it with a hammer, problem solved.
