U/D Pulley
Old Jun 6, 2009 | 05:32 PM
2002 SS's Avatar
Default U/D Pulley
Can sombody tell me the exactly dampner puller ill need to swap. also how do i take the pulley off? do i take the pulley bolt out than put the puller in the inner ridges and turn it to the left till it falls out?? im still a newb so any help will be appreciated. thanks
Old Jun 7, 2009 | 08:58 AM
Black 99 Bird's Avatar
I would go with a power bond pulley, most sponsers carry them. As far as removal, you need a 3 jaw puller small enough to fit inside the stock pulley. I rented mine from Auto Zone. I backed the bolt out a little, then pulled. Then backed it out some more and pulled it again until it came off. Make sure you get a new replacement bolt. And follow the replacement instructions.
