Converter compatible?
Old Jun 11, 2009 | 10:21 PM
airmaxon1's Avatar
Default Converter compatible?
Will 00' Z28 catalytic converters work on a 99' Trans Am? Thanks!
Old Jun 11, 2009 | 10:42 PM
johnLs1camaro's Avatar
shouldnt have a problem...
Old Jun 12, 2009 | 04:25 PM
98TAjwh's Avatar
no they won't, ask me how i know
Old Jun 12, 2009 | 04:38 PM
really, i thought 98-00 was the same and then 01-02 they changed it up.
Old Jun 12, 2009 | 04:46 PM
98TAjwh's Avatar
nope, pretty sure they change the exhaust setup on the 00 model. anyone can correct me if i'm wrong.
Old Jun 12, 2009 | 04:50 PM
98TAjwh's Avatar
if you want to put a 00 converter on a 99 you'd have to use the 00 headers, cats and y-pipe. unless you are just replacing the driver side cat. that will fit.
Old Jun 12, 2009 | 05:29 PM
Fireberg's Avatar
98 TA is right, I just did this on my 99.
Beginning on the Y2K F-Bodies GM changed over to the cast iron exhaust manifolds.
When they did this, the location where the passenger side exhaust manifold connects to the cat moved further forward.
Also on the pre 2000 cars the passenger cat is a single piece with the Y-Pipe, it was not flanged in like the later cars.
