Will it run?!?!?!?!?
Old Jun 17, 2009 | 11:51 PM
youguessit's Avatar
Question Will it run?!?!?!?!?
have an 02 camaro...already running lean from tfs head install it is an a4. Wondering if the car will be driveable if i put fast 92 92 setup on it? I have to drive pretty far to get it tuned.
Old Jun 18, 2009 | 07:36 AM
BlackScreaminMachine's Avatar
Internet Mechanic
If you can get it towed, tow it. If you cannot, then NO WOT driving. cars can run lean when its not 100% throttle. Most good tuners can set up cars to do that.
Old Jun 18, 2009 | 11:53 AM
youguessit's Avatar
what i am most worried about is the difference in the throttle body size... i had a tps sensor that was only .2 off and the car ran like complete ****.... wondering if it will even be driveable with the huge difference in throttlebody size.
Old Jun 18, 2009 | 12:56 PM
Internet Mechanic
TPS volts is alot different then the size of the TB. At a given throttle opening. The PCM does not like when the TPS volt is not in spec, especially if it is a automatic since it relies on the infomation. I know what your talking about. Most people slot the TPS for adjustment, thats what I did on my old LT1 car, worked great.
