ARP head torque question
Old Jul 3, 2009 | 09:38 PM
maxgee's Avatar
Default ARP head torque question
question, when torquing i did 30 50 70 following what i've found on this site.
arp recommends tightening and loosening 5 times. do they mean torque to 70ft lbs then loosen and retorque 5 times?
Old Jul 4, 2009 | 12:35 PM
Damian's Avatar
LSX Mechanic
Do not TQ and loosen. Go in the GM sequence with your 30-50-70 intervals, and leave it alone.
I always let it sit for at least an hour, and go back and hit them one more time with the final 70ft lb pass.
Old Jul 4, 2009 | 08:16 PM
S10xGN's Avatar
Bad info! ARP says torque 5x's (with lube) for a reason. This allows the washer / fastener to "bed in" which reduces the friction quite a lot. If you've ever done it, you'll see the head of the fastener turn a bit further with every torqueing (which shows that more of the force is going to turn the fastener and less is being absorbed by friction).
Russ
