Ls6 intake install supplies?
Old Jul 8, 2009 | 05:25 PM
Bad98SS's Avatar
Question Ls6 intake install supplies?
I just bougth an ls6 intake for my 98 camaro ss. What supples do i need to have and or other parts. Also what intake gaskits should i use? Any tips would be great also. Thanks
Old Jul 8, 2009 | 07:39 PM
conan's Avatar
You'll need this for the coolant tube. http://www.texas-speed.com/shop/cate...MID=1&catid=12
Gaskets you can get at the dealership, carquest, i think napa too.
You'll also need to get a block off plate for the egr, unless you already removed it.
http://www.ls1howto.com/index.php?article=5
Old Jul 9, 2009 | 12:24 AM
94dragbird's Avatar
Is there any negative side affects with just blocking off the back coolant openings? I here a lot about heat issues on the #7 and #8 cylinders.
Old Jul 9, 2009 | 10:12 AM
crossroads's Avatar
^ I kept my LS1 tubes and just smoothed the bottom of the LS6 intake, fit perfect
Old Jul 9, 2009 | 10:49 AM
Noxious's Avatar
How did you smooth it?
Old Jul 9, 2009 | 12:01 PM
94dragbird's Avatar
hammer and chisel works best from what I've heard
