How do I keep the crank from moving?
Old Nov 16, 2003 | 09:25 AM
jpbgto's Avatar
Default How do I keep the crank from moving?
I got my old crank pulley off and have put on the asp one but i can't torque it down the crank keeps on turning. How do I keep it from turning?
Old Nov 16, 2003 | 09:41 AM
DARK AGE 53's Avatar
Did you put the tranny in 5th gear?
Old Nov 16, 2003 | 10:01 AM
jpbgto's Avatar
sure didn't I will try it. stupid question but should i have done this the whole time?
Old Nov 16, 2003 | 11:27 AM
If you had a problem with the crank turning it probably might have helped, let us know how it turns out. Good luck.
Al
Old Nov 16, 2003 | 12:35 PM
jpbgto's Avatar
That worked out just right. I finally got everything tightened down and went for a drive everything seems to be running fine. Thanks for the help. By the way do you know the size hose that runs from the the radiator to the throttle body?
Old Nov 16, 2003 | 12:36 PM
jpbgto's Avatar
Can you send some pics of your car, I think I have seen that issue but I can't remember. thanks
Old Feb 13, 2004 | 01:40 PM
ls1perfcar?'s Avatar
How can i install my crank pulley if the motor is out of the car? Or would it be easier to wait till i had it in the car. Since my car isnt a standard does drive compensate for 5th gear or what?
