exhaust clamps
http://www.stainlessworks.net/cart/i...ath=95_367_141
Or you could put 2-4 spot welds on each pipe connection, then also use the single bolt band clamps.
I found that the larger 2 bolt band band clamps work best for a daily driver, otherwise moisture has a tendency to rust the pipes under the clamps.
