noise after header install
Old Nov 18, 2003 | 12:38 PM
DangeRuSS's Avatar
Default noise after header install
car is a 02 SS, installed Hooker long tubes with ORY. now at certain times while accelerating the car makes a flutter type noise and somedays its louder than others? Any ideas or is this normal for headers?
Thanks.
Old Nov 18, 2003 | 02:10 PM
blkZ28spt's Avatar
Did you use AIR restrictor plates? Might want to search on that topic, most LT's need them to keep the AIR check valves from burning up I think.
Old Nov 18, 2003 | 03:57 PM
taJon's Avatar
Is it possible that the gasket didn't seat properly and you have an exhuast leak at the header?
Old Nov 18, 2003 | 05:12 PM
cudaeh's Avatar
flutter? does it sound like all the heat shealds are ratteling under the car all at the same time or is it like a popping noise.
rattle= rasp= add bullet mufflers before main muffler
popping= hole some where neer header
Old Nov 18, 2003 | 06:50 PM
DangeRuSS's Avatar
Not a popping noise more like a rattle. when driving I hear it more on the driver side of the vehicle. does not resemble an exhaust leak to me. thanks for the replies.
Old Nov 18, 2003 | 07:21 PM
jrp's Avatar
jrp
SN95 Director
my vote is check valves if you still have your air system hooked up.
Old Nov 19, 2003 | 06:59 AM
silverTA's Avatar
check the Y pipe where its hooked to driver side header
Old Nov 19, 2003 | 08:10 AM
cudaeh's Avatar
if it only happens at certent rpm ranges under load then i think its rasp. it happend to my car. i installed mac midlengts and it sounds like a monkey hitting a tin can at 2500 rpm under a load. at first i thought it was the heat shields ratteling at first but it persisted after removing most of them later i found out that the raspy noise was commen with headers and is easily solved by throwing in a couple of bullett muffelers... i havent bothered to fix it yet.. im getting more lazy and the probablem is becomming less annoying.
 Michael S. Palmer
Old Nov 19, 2003 | 08:32 AM
LS1INSIDE's Avatar
check the a.i.r valves and buy some restrictor plates I have the same flutter w/o headers
Old Nov 19, 2003 | 08:55 AM
joshs2000ss's Avatar
Mine does that as well. I think it's more commonly know as the dreaded piston slap, notorious to LS1's. I'm gonna try to go from 5w-30 Mobil 1 to 10w-30 on the next oil change to try and remedy the issue.
Old Nov 19, 2003 | 06:54 PM
mcflyz28's Avatar
Go buy more air tube gaskets and cut two peices of metal it's your check valves.
Old Nov 21, 2003 | 11:13 AM
DangeRuSS's Avatar
Thanks for the replies guys. Im gonna try the plate trick for the AIR tubes.
Old Nov 21, 2003 | 05:03 PM
Wicked's Avatar
Just curious. I have what i think is the same noise after a header install. I changed both check valves after creating two restrictor plates sandwiched between 2 AIR gaskets. The opening is 3/16." I still get a flutter under heavier acceleration tho. Any thoughts?
