too rish at wot. stock ls1
Old Jul 26, 2009 | 04:22 PM
awd-rwd racer's Avatar
Default too rish at wot. stock ls1
i have a 01 ls1 with long tubes and a cold air intake. custom dual 3" exhaust. i also have sped inc fuel rails. @ wot my aem wideband is reading that the air fuel ratio is 10.0-10.5. is that normal? i have fuel pressure set to 58psi. ive heard that with the lth's it would run richer then it should but in the 10's?
Old Jul 26, 2009 | 05:25 PM
slowrollin93's Avatar
Back when I had my wideband on I would run 12.5-12.7 @WOT and I had longtubes, cai, and a tune back then. I deffinetly think you are too rich, whats it read at idle and cruising.
Old Jul 26, 2009 | 05:34 PM
idle and crusie are usually between 13-15~. although sometimes my idles shows very lean and then will go back to 15. do you have any idea what your wot was b4 u had a tune?
Old Jul 26, 2009 | 07:42 PM
I had a tune before i had the wideband, but I drove around without a it tuned for the longtubes and the afr was right around the same.
Old Jul 26, 2009 | 08:08 PM
DaddySS's Avatar
You need to get it tuned with LTs, that'll solve your AFR issue
Old Jul 26, 2009 | 08:14 PM
i understand that. my main question is that is it typically that rich. "in the 10's"
