ls6 intake swap question
Old Jul 26, 2009 | 11:18 PM
b-ron's Avatar
Default ls6 intake swap question
I just purchased a ls6 intake and 80mm tb
I'm going to be doing the ls1 to ls6 intake swap on my 00ws6 tommorow
from what I've read I just need to be careful removing the intake so I don't damage the oil sending unit and block off the egr with block off plates
and I'll prob replace the gaskets since I'm going to be their.
The only question I have is can i reuse the coolant hoses or do I have to upgrade to 01 hoses,and also I think I have to grind something down on the intake. Any help and info would be helpful thanks.
anyone have any ideas on hp gain for both intake and tb upgrade?
Old Jul 26, 2009 | 11:53 PM
b-ron's Avatar
only need a little help guys
Old Jul 27, 2009 | 01:13 AM
HitmanLS1's Avatar
Are you going to do the TB bypass?
Old Jul 27, 2009 | 06:07 AM
b-ron's Avatar
??? what is that?
Old Jul 27, 2009 | 06:10 AM
b-ron's Avatar
about to start the swap still trying to get a few ansers to the above questions
thanks guys
Old Jul 27, 2009 | 06:23 AM
jmill96Z's Avatar
http://www.ls1howto.com/index.php?article=5
One thing they don't tell you is to use rubber bands on the rear 4 bolts (2 per side) to hold them in up while you remove and install the intake. It'll save you a little headache
Old Jul 27, 2009 | 06:33 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
knock the ribs off the bottom of the intake and hammer the coolant lines as close to the valley cover as possible
Old Jul 27, 2009 | 06:57 AM
b-ron's Avatar
any body have a picture of the above statement
which part of the bottom of the intake are considered the ribs
Old Jul 27, 2009 | 11:41 AM
tording99Z28's Avatar
The ribs are on the bottom of the intake on the flat section. They are like little lines in a grid pattern that you grind them until they are flat. You only need to grind the ribs where the coolant lines sit, not the whole thing.
Old Jul 27, 2009 | 02:57 PM
HitmanLS1's Avatar
Nice write up
Old Jul 27, 2009 | 05:21 PM
b-ron's Avatar
thanks for the info
