Keyed Power Source
Old Jul 28, 2009 | 08:38 AM
Auto's Avatar
Default Keyed Power Source
I have bought a qtp electric cut for my bola system. I need to hook up the cut out and I was looking for a good keyed power source because I do not drive the car every day and I do not want this to draw on the battery. Does anyone have any suggestions? Also if anyone is using the cut out where did you mount your switch. I was looking into the ash tray but it looks like it will be some work to make that fit there.
Old Jul 28, 2009 | 09:17 AM
teke184's Avatar
ignition in the under-hood fuse box would work, as would the fuel pump.
i've used the radio for a source before if you really want something in the cabin.
here is where i put the switch for my fan switch....out of the way but easily accessible. although i don't use my cig lighter, and the 2ndary power port works for any other needs.
oops..forgot the pic
Old Jul 28, 2009 | 09:31 AM
Auto's Avatar
The look nice thanks for the good idea.
Old Jul 28, 2009 | 01:57 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Got an owner's manual?
If you look in there, it will show you where you can get retained accessory, key-on, and always hot 12V power from the fuse panel just inside the driver's door. All you need is a wire and a standard male spade connector.
For your application, you'll want either the retained accessory (key-on, but stays on after you shut the car off until you open the door) or the switched (key-on only) 12V power source.
Old Jul 28, 2009 | 02:30 PM
Auto's Avatar
I will check my owner manual when i get home. Thanks i did not know about that.
Old Jul 28, 2009 | 02:40 PM
MeentSS02's Avatar
Neither did I...I stumbled upon it by accident when I was bored one day.
