Guide pins For block to trans alignment
Old Aug 17, 2009 | 10:56 AM
pbj-tj's Avatar
Default Guide pins For block to trans alignment
Just had my LS1 Rebuilt and picked up a 4L60e
Was going to bolt the two togeather, but there are no guide pins...
I just picked up a set of guide pins from the dealership.
Question is, can I tap these pins into the block? or will I have to have them pressed in? Seems like tapping them in could be a little dangerous on the aluminum block, but I figured I could save alot of time and effort if I could just tap them in. Thanks
Old Aug 17, 2009 | 11:10 AM
Marc 85Z28's Avatar
Just lightly hit them in. Don't use a sledgehammer or anything like that.
Old Aug 17, 2009 | 11:12 AM
pbj-tj's Avatar
Sounds good, I didnt want to have to move the whole motor somewhere just to get these pressed in, thanks man.
Old Aug 17, 2009 | 11:23 AM
twitchtwice's Avatar
yeah, and you want to go in from the back to the front. so standing under the car looking towards the front. and like mentioned just tap it with a hammer.
Old Aug 17, 2009 | 12:10 PM
pbj-tj's Avatar
cool thanks
Old Aug 17, 2009 | 12:37 PM
01ssreda4's Avatar
I dont see why you couldn't put a little motor oil on them to lube them up going in
Old Aug 17, 2009 | 08:51 PM
pbj-tj's Avatar
Ya I guess some motor oil couldnt of hurt, but i had already tapped them in carefully with a hammer, no problems. Thanks all
