Which cut out for Qtech?
Old Nov 23, 2003 | 10:23 PM
KrazyDan's Avatar
Default Which cut out for Qtech?
I bought a flowtech cut out with qtech but the bolts arent long enough to attach to qtech . i was wondering which cut out you guys are using for your qtech. And where can i find it. thanks for your help guys.
Old Nov 23, 2003 | 10:28 PM
WILWAXU's Avatar
hmm.. it fit my Flowtech?
Old Nov 24, 2003 | 12:08 AM
Mike K.'s Avatar
Fit mine as well, how short are yours from fitting? Mine did not have much room but they did fit.
Old Nov 24, 2003 | 01:09 AM
Cheatin' Chad's Avatar
Fit my Flowtech.
Wow! is that Flowtech a POS though. Half the pipe was not cut out where they attached the y pipe.Some of the cobbiest welds I have EVER seen.
With the level of QC present I wouldn't doubt the welded the studs improperly on a few of em.
Next time I'll be making my own..
Old Nov 24, 2003 | 03:42 AM
jaberwaki's Avatar
sound like you got a bad one... call and complain... theyshould make it right
Old Nov 24, 2003 | 05:47 AM
Slowhawk's Avatar
LS1Tech Sponsor
I just cut off the old studs and welded on longer ones.
Old Nov 24, 2003 | 09:13 AM
jamnut's Avatar
That's exactly what I did, I made mine longer before I ever put the flowtech on so I would have enough bolt so I could bolt on a turn down if I wanted to, which I am fixing to do.
Old Nov 24, 2003 | 05:46 PM
KrazyDan's Avatar
I got a email from qtech today and they said to throw out the gasket and use high temp silicone. think it would work???????
 Michael S. Palmer
Old Nov 24, 2003 | 11:48 PM
WILWAXU's Avatar
I would say Q-Tech are the experts
Old Nov 25, 2003 | 12:08 AM
Colonel's Avatar
That's what I did and it's been working just fine like that for over a year.
Old Nov 25, 2003 | 11:23 AM
skytower31's Avatar
I had heard of the short bolts from the beginning when using the qtec cutout so I cutoff the bolts before I had it welded in and just used longer bolts. Did even weld the new ones in, just cranked it down with a little lock-tite. Works great. I would rather have longer bolts and not have to worry about only getting a few threads of the nut through.
Old Nov 25, 2003 | 09:36 PM
Zero_FactiX's Avatar
I used RTV red silicone on mine and it worked great.
